vcSetPropertyStatement
A statement that sets the value of a property. The property can be in the routine that owns this statement, or in an object higher up in the object hierarchy.
Module: vcRobotics2
TargetPropertyNamevcPropertyRGets a name of the property to which the value will be assigned to.
ValuevcPropertyRGets an expression that, when evaluated, returns the value to assign to the target property. Signal map expressions are allowed.
